[GRASS5] [bug #859] (grass) raster data at lower resolution: no resampling...
Markus Neteler neteler at itc.it
Tue Nov 27 11:47:52 EST 2001
On Tue, Nov 27, 2001 at 10:31:04AM -0500, Helena Mitasova wrote:
> Markus Neteler wrote:
> > O.k. - the problem is that I have no idea what "resampled" means in
> > this case. It seems that we have to study the related sources.I just want
> > to understand what's happening.
> I guess you should really look at the source and then write what you have found
> into the prog manual and users manual (probably for g.region entry).
> Does anybody know what it is doing already, to save Markus some time?
Well,  I need assistance since I don't understand the code :-)
It should be here:
src/libes/gis/get_row.c
 *   Step 2:  Convert the data into a CPU readable format, and subsequently
 *            resample the data. the data is stored in a second intermediate
 *            buffer (the type of the data in this buffer is Y)....
Maybe someone professional looks with doxygen or whatever at the
dependencies. Is it done in XDR or somewhere else? And what is done?
> > Does it make sense print a warning in this case? To make the user
> > aware that the resolution doesn't match?
> > At least when exporting data or using r.mapcalc this is quite important.
> I agree with that, but I am not sure how much work it would be.
> It would certainly be beneficial if r.mapcalc let user know
> e.g. when computing C=A+B+D it could write : Warning, resampling map A to match
> the resolution.
> When exporting, it would be useful too. In r.flow, where it really matters,
> we just say that "your resolution does not match the current resolution" and exit
> so the user has to fisrt change his region to that of the elevation input or
> resample/reinterpolate
> his elevation. So it is really application and data dependent.
> Helena
Thanks for your comments. I fear we have to dig into the code to
find out the current implementation. From that we may decide if and
where to implement user notifications.
Markus
