[GRASS5] [bug #863] (grass) 2 bugs in GIS lib: reclass maps
Glynn Clements glynn.clements at virgin.net
Fri Nov 30 00:07:39 EST 2001
Request Tracker wrote:
> I have found two bugs in the GIS library: The reclass-test function is
> not working properly when a raster and and vector map with identical
> name exist (which is usually no problem).
Can you elaborate?
> And you can't delete the base
> map of a reclass map, if you first delete the reclass map
This is discussed in the thread for [bug #837].
Glynn Clements <glynn.clements at virgin.net>
