[GRASS5] s.proj site header
Markus Neteler
neteler at itc.it
Mon Oct 1 08:04:18 EDT 2001
Helena,
On Fri, Sep 28, 2001 at 07:08:56PM -0500, Helena wrote:
> Markus,
> the quick reference of GRASS ascii formats is at
> http://skagit.meas.ncsu.edu/~helena/grasswork/format.html
> So if it is OK please put it at
> http://grass.itc.it/gdp/html_grass5/index.html
> under reference manual sections
Thanks for this, I have added it in CVS. You find it online
now as proposed.
> Actually I noticed that the site ascii format has been
> included into description of s.in.ascii in the users manual
> however the info about the header was not included, so
> you may want to put it there too.
> (http://grass.itc.it/gdp/html_grass5/html/s.in.ascii.html)
Yes, done. I also added the cross-ref to the ASCII formats page.
> >A new implementation seen in s.in.shape is there, but commented.
> what do you mean by this?
I have borrowed the code from s.in.shape to write the timestamp,
put I got lost with strings/pointers, so you find this code
commented in s.proj. At time (CVS version) the "desc" is not
written any more. If someone could check the s.proj/main.c -
will be easy to finish that for a strings/sites expert (hi Eric :-)
> >The time stamp facility does not appear to work at present.
> I found this in manual for s.in.shape - does this mean that the time stamp
> associated with the shape file is not imported?
I don't know, but I think it will be working in s.in.shape. Please note
that from a C standpoint the implementation in s.in.shape and s.proj
slightly differ (some pointers stuff).
Markus
> Markus Neteler wrote:
> > On Thu, Sep 27, 2001 at 04:12:44PM -0500, Helena wrote:
> > > This appears to be a small but annoing bug - s.proj puts a comment at the
> > > beginning of a projected
> > > file, however other programs such as s.info do not like it
> > > s.info lidar.utm
> > > ERROR: G_site_new_struct: invalid # dims or fields
> > > # s.proj input=lidar99 location=coastll mapset=helena dbase=/data/grassdata
> > > output=lidar99.utm
> > > 443873.48614701|3978547.65291465|#1 %5.054
> > > So you have to remove it manually.
> > > To keep the useful info on where the data came from I believe that instead of
> > > #s.proj.......
> > > this info should be passed as
> > > description|s.proj.......
> > > It is in main.c here:
> > > if(outfile){ /* also write G_recreate_command as comment */
> > > Site_head sh;
> > > char buf[80];
> > > fprintf(outfile,"# %s\n", G_recreate_command());
> > > G_site_get_head (infile, &sh);
> > > G_site_put_head (outfile, &sh);
> > > Can somebody please fix it, in case that it has not been done already.
> > Hi again,
> > I have modified the s.proj, now it doesn't write the desc in old style
> > any more. A new implementation seen in s.in.shape is there, but commented.
> > It needs to be finished (no time, sorry). See in CVS.
> > Ciao
> > Markus
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
