[GRASS5] Darwin Pre2: PNGDriver
jeshua
jeshua at SierraMaps.com
Sat Oct 13 19:45:43 EDT 2001
On Saturday, October 13, 2001, at 04:45 AM, Glynn Clements wrote:
>> configure:4710: checking for png_read_png in -lpng
>> configure:4729: gcc -o conftest -O2 conftest.c -lpng -lz 1>&5
>> /usr/bin/ld: Undefined symbols:
>> _png_read_png
> OK; apparently this is function is optional (it only exists if libpng
> was compiled with PNG_INFO_IMAGE_SUPPORTED defined. I'll check for
> png_read_image (which is actually used by r.in.png) instead.
> I'm about to commit a new version of configure[.in] which fixes all of
> the aforementioned problems.
Thanks Glynn,
Can you please let me know when I can check it out?
Will I have to re-build everything and start out with a "make
distclean", or will I be able to just run configure and then build the
PNGDriver?
Thanks again,
Jeshua Lacock http://OpenOSX.com
Programmer/Owner http://SierraMaps.com
Phone: (760) 935-4736 http://3dTopoMaps.com
