[GRASS5] Darwin Pre2: PNGDriver
Glynn Clements
glynn.clements at virgin.net
Sun Oct 14 03:41:35 EDT 2001
jeshua wrote:
> >> configure:4710: checking for png_read_png in -lpng
> >> configure:4729: gcc -o conftest -O2 conftest.c -lpng -lz 1>&5
> >> /usr/bin/ld: Undefined symbols:
> >> _png_read_png
> > OK; apparently this is function is optional (it only exists if libpng
> > was compiled with PNG_INFO_IMAGE_SUPPORTED defined. I'll check for
> > png_read_image (which is actually used by r.in.png) instead.
> > I'm about to commit a new version of configure[.in] which fixes all of
> > the aforementioned problems.
> Thanks Glynn,
> Can you please let me know when I can check it out?
It's ready; if I say "about to commit", it will probably be done
within a few minutes of the email being sent.
> Will I have to re-build everything and start out with a "make
> distclean", or will I be able to just run configure and then build the
> PNGDriver?
It should suffice to run configure then build PNGdriver.
Glynn Clements <glynn.clements at virgin.net>
