[GRASS5] Temporal data in GRASS?
Carl Worth
cworth at east.isi.edu
Fri Oct 26 09:56:40 EDT 2001
Markus Neteler writes:
> I have just added from the exp tree (unused/ section) a module
> from Huidae Cho:
> src/display/d.text.freetype
Excellent, I'll have a look at this.
> In general you should give r.in.gdal a try. It supports a large
> range of formats. But, first, you may try to zoom the raster map:
> g.region rast=imported_map
Whoops... that was my problem. Somehow I thought my elevation and map
data were for the exact same region, but I guess not. I feel foolish.
Well, thanks for the help. :)
-Carl
