[GRASS5] difficulties with r.proj (was: Temporal data in GRASS?)
Carl Worth
cworth at east.isi.edu
Fri Oct 26 17:19:14 EDT 2001
Carl Worth writes:
> Markus Neteler writes:
> > g.region rast=imported_map
> Whoops... that was my problem. Somehow I thought my elevation and map
> data were for the exact same region, but I guess not. I feel foolish.
I'm making headway, but I'm also causing new problems.
My two datasets *are* both for the same region -- the problem was that
the data were in two different projections, (UTM vs. Albers Equal
Area). I've now got each one imported into its own location and I can
view each one separately just fine.
But, of course, I'd like to see them together, so I need to transform
one into the projection of the other. r.proj looks to fit the bill
exactly, but I'm getting the following:
GRASS > r.proj input=amap location=albers
cannot initialize pj
cause: projection not named
ERROR: Can't get projection key values of output map
My current location seems to have a well-defined projection:
PROJECTION: 1 (UTM)
DATUM: NAD27
ELLIPSOID: clrk66
so what could I be missing?
Hmmm... I'm stepping through r.proj in gdb now. It looks like if
PROJ_INFO has one of "name", "tinit", or "sproj" that I might get past
the current problem. So what would I name my projection? Maybe "name:
utm". With that I now get:
cause: major axis or radius = 0 or not given
Now it appears to be trying to load some projection parameters based
on the name of my projection. It's trying to look in PROJ_LIB, (which
is not set). I'm feeling like I must not have installed something...
Hmm... programmers manual talks about PROJ4. Do I have to install that
separately?
I'll keep poking.
Any light that could be shed would be most appreciated.
-Carl (Who is anxious to start contributing rather than continually
exposing his ignorance in public forums)
Carl Worth
USC Information Sciences Institute cworth at east.isi.edu
3811 N. Fairfax Dr. #200, Arlington VA 22203 703-812-3725
