[GRASS5] pre2 nviz & darwin -- part ii
Helena
hmitaso at unity.ncsu.edu
Fri Oct 26 14:41:45 EDT 2001
Bob Covill wrote:
> Glynn Clements wrote:
> > andy agena wrote:
> > > >> however, if i try nviz from tcltkgrass, the command passed is "nviz
> > > >> el=elevation.dem", which gives "Sorry, <el=> is ambiguous".
> > > > Odd; that works fine here, both from the command line and via
> > > > tcltkgrass.
> > > > What does "nviz help" say?
> > > GRASS 5.0.0pre2 > nviz help
> > [snip]
> > That implies that the error message is bogus, i.e. a problem with
> > G_parser(), but I can't see anything obvious.
> > Glynn Clements <glynn.clements at virgin.net>
> I am guessing here, but is it possible that TCL (tcltkgrass) is getting
> confused with the command? In other words is it reporting the error
> before it even gets to G_parser?
> It might help to know what the raster file name is that is creating the
> problem in case of odd characters. Or is it "elevation.dem".
it gives him the same error even if he just calls nviz -q, so it is not in
the name,
if I understand it correctly. Andy, does it open any of the windows when you
start nviz -q
(the graphics window, "please wait" window and then the tcltk interface)?
Helena
> Bob Covill
> Tekmap Consulting
> E-Mail: bcovill at tekmap.ns.ca
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
