[GRASS5] pre2 nviz & darwin -- part ii
Glynn Clements glynn.clements at virgin.net
Fri Oct 26 16:53:05 EDT 2001
andy agena wrote:
> this is the console output i get when i fire up xwindows (i've snipped
> the piece about 'if your version is old..').  do you think any of this
> is relevant to my problems?
> Warning: no access to tty (Inappropriate ioctl for device).
> Thus no job control in this shell.
> _XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
> /usr/X11R6/lib/X11/xinit/xinitrc: command not found: fspanel [30]
I can't see how any of these could cause the error message in
question.
Glynn Clements <glynn.clements at virgin.net>
