[GRASS5] pre2 nviz & darwin -- part ii
andy agena
andya at mac.com
Fri Oct 26 13:54:42 EDT 2001
hi glynn:
this is the console output i get when i fire up xwindows (i've snipped
the piece about 'if your version is old..'). do you think any of this
is relevant to my problems?
thanks,
andy
Warning: no access to tty (Inappropriate ioctl for device).
Thus no job control in this shell.
_XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
/usr/X11R6/lib/X11/xinit/xinitrc: command not found: fspanel [30]
On Friday, October 26, 2001, at 12:09 PM, Glynn Clements wrote:
> andy agena wrote:
>>>> however, if i try nviz from tcltkgrass, the command passed is "nviz
>>>> el=elevation.dem", which gives "Sorry, <el=> is ambiguous".
>>> Odd; that works fine here, both from the command line and via
>>> tcltkgrass.
>>> What does "nviz help" say?
>> GRASS 5.0.0pre2 > nviz help
> [snip]
> That implies that the error message is bogus, i.e. a problem with
> G_parser(), but I can't see anything obvious.
> Glynn Clements <glynn.clements at virgin.net>
