[GRASS5] pre2 nviz & darwin -- part ii
Jeshua Lacock jeshua at SierraMaps.com
Sat Oct 27 04:39:46 EDT 2001
On Friday, October 26, 2001, at 02:53 PM, andy agena wrote:
> nviz -q (with or without tcltkgrass running) very briefly flashes the
> "wait_ok" and nviz boxes, then gives the '"wait_ok" already exists in
> parent' error in the xterm.  the nviz i/o box doesn't appear.
> using the tcltkgrass menu for nviz pops up three windows (wait_ok, nviz
> i/o, and  nviz), nviz i/o says:  'loading data,' 'update elev null
> mask,' 'loading data,' 'translating colors,' then ends with 'sorry,
> <el=> is ambiguous' (this "el=" is passed from the command line box in
> the nviz dialog and i can't edit it).
Hi guys,
I now get the same thing.  Which is weird, because it was working here
before I switched to my new dual-processor machine and installed Grass
from my CD.
Here are the errors that I get after running nviz -q
[...snip...]
ERROR: window name "wait_ok" already exists in parent
child process exited abnormally
     while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script -q -name NVIZ
 >&@stdout"
     ("eval" body line 1)
     invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ
 >&@stdout"
     invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
     (file "/usr/local/grass5/bin/nviz" line 13)
Tcltkgrass operates normally.
Any ideas?
Thanks,
Jeshua Lacock                                http://OpenOSX.com
Programmer/Owner                     http://SierraMaps.com
Phone: (760) 935-4736            http://3dTopoMaps.com
