[GRASS5] pre2 nviz & darwin -- part ii
Glynn Clements glynn.clements at virgin.net
Sat Oct 27 18:10:52 EDT 2001
Jeshua Lacock wrote:
> > nviz -q (with or without tcltkgrass running) very briefly flashes the
> > "wait_ok" and nviz boxes, then gives the '"wait_ok" already exists in
> > parent' error in the xterm.  the nviz i/o box doesn't appear.
> > using the tcltkgrass menu for nviz pops up three windows (wait_ok, nviz
> > i/o, and  nviz), nviz i/o says:  'loading data,' 'update elev null
> > mask,' 'loading data,' 'translating colors,' then ends with 'sorry,
> > <el=> is ambiguous' (this "el=" is passed from the command line box in
> > the nviz dialog and i can't edit it).
> I now get the same thing.  Which is weird, because it was working here
> before I switched to my new dual-processor machine and installed Grass
> from my CD.
Revert src.contrib/GMSL/NVIZ2.2/src/nvizAppInit.c to version 1.1, i.e.
	cvs update -r 1.1 src.contrib/GMSL/NVIZ2.2/src/nvizAppInit.c
This won't fix the problem, but hopefully it will provide an
indication of why Tk_Init() failed.
Glynn Clements <glynn.clements at virgin.net>
