[GRASS5] pre2 nviz & darwin -- part ii
Jeshua Lacock
jeshua at SierraMaps.com
Sun Oct 28 02:27:30 EST 2001
On Saturday, October 27, 2001, at 10:00 AM, Glynn Clements wrote:
> In short, the symptoms which you describe are exactly what I would
> expect to happen if Ninit() was called twice.
> Try changing the first block of code above to e.g.:
> if (Tk_Init(interp) == TCL_ERROR) {
> fprintf(stderr, "Tk_Init failed\n");
> return TCL_ERROR;
Hi Glynn,
Thanks, I changed the code as you have kindly provided.
I then deleted the OBJ directory (in the nviz directory). Next I ran
gmake5, gmakelinks5. I then deleted the nviz binary, followed by a make
install in the /usr/src/grass directory.
But no matter what the nviz binary is dated oct 12 - the day I built the
Pre2 binaries.
Do I have do do a make clean and reconfigure again? I would like to
avoid recompiling the entire build again if it can be helped.
Thanks,
Jeshua Lacock http://OpenOSX.com
Programmer/Owner http://SierraMaps.com
Phone: (760) 935-4736 http://3dTopoMaps.com
