[GRASS5] [bug #801] (grass) compilation errors in  grass5.0.0pre2
    Glynn Clements
    glynn.clements at virgin.net
    Fri Sep 14 03:35:46 EDT 2001
Request Tracker wrote:
> Compilation error in module: src/imagery/i.fft (ignored)
> Compilation error in module: src/imagery/i.zc (ignored)
> Compilation error in module: src/raster/r.surf.fractal (ignored)
> Compilation error in module: src.contrib/CERL/imagery/i.shape (ignored)
As it says in REQUIREMENTS.html, you need the FFTW library for these
programs (but the rest of GRASS will work fine without it).
> Also
> gmake5 src.garden/grass.postgresql
> caused
> make[1]: Entering directory `/usr/local/src/grass5sources/grass5.0.0pre2/src.garden/grass.postgresql/d.rast.pg'
> gcc -g -O2  -I/usr/local/src/grass5sources/grass5.0.0pre2/src/include   -c runInfxFile.c -o OBJ.i686-pc-linux-gnu/runInfxFile.o
> runInfxFile.c:6:22: libpq-fe.h: No such file or directory
Didn't configure give you the following warning?
	configure: warning: *** Unable to locate PostgreSQL includes.
NB: "./configure --help" tells you what switches are available to
change the directories which are searched for include files.
Glynn Clements <glynn.clements at virgin.net>
