[GRASS5] [bug #801] (grass) compilation errors in grass5.0.0pre2
Bernhard Reiter bernhard at intevation.de
Mon Sep 17 09:58:01 EDT 2001
IMO configure should stop of
FFTW or postgresql files are missing.
If you then want it without these libraries you have to run the
accordings configure options.
	Bernhard
On Fri, Sep 14, 2001 at 08:35:46AM +0100, Glynn Clements wrote:
> Request Tracker wrote:
> > Compilation error in module: src/imagery/i.fft (ignored)
> > Compilation error in module: src/imagery/i.zc (ignored)
> > Compilation error in module: src/raster/r.surf.fractal (ignored)
> > Compilation error in module: src.contrib/CERL/imagery/i.shape (ignored)
> As it says in REQUIREMENTS.html, you need the FFTW library for these
> programs (but the rest of GRASS will work fine without it).
> > Also
> > gmake5 src.garden/grass.postgresql
> > caused
> > make[1]: Entering directory `/usr/local/src/grass5sources/grass5.0.0pre2/src.garden/grass.postgresql/d.rast.pg'
> > gcc -g -O2  -I/usr/local/src/grass5sources/grass5.0.0pre2/src/include   -c runInfxFile.c -o OBJ.i686-pc-linux-gnu/runInfxFile.o
> > runInfxFile.c:6:22: libpq-fe.h: No such file or directory
> Didn't configure give you the following warning?
> 	configure: warning: *** Unable to locate PostgreSQL includes.
> NB: "./configure --help" tells you what switches are available to
> change the directories which are searched for include files.
> Glynn Clements <glynn.clements at virgin.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Geschäftsführer, Intevation GmbH                    (intevation.de)
Projekt Freie GIS Software              (freegis.org/index.de.html)
FFII e.V.				                 (ffii.org)
FSF Europa     			      (fsfeurope.org/index.de.html)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010917/38c2feef/attachment.bin
