[GRASS5] configure on cygwin, freebsd, solaris, irix
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Sep 20 19:16:01 EDT 2001
i tested the latest configure on cygwin, FreeBSD/alpha, Solaris/SPARC
and IRIX.
I will upload the output (config.log, config.status and output of
./configure) to:
http://mitglied.tripod.de/AndreasLange/igrass/index.html FYI.
As i generated the output in the last days, only the IRIX part is
identical with the latest CVS.
The gd lib is still not recognized correctly on cygwin, solaris and
irix. I think the configure tests for the wrong function, if i override
the #ifdefs in the code i can compile a fully functional PNGdriver on
cygwin (without changing anything else). So i can at least narrow down
that it is not the missing gdImagePng function in libgd.
On cygwin i have the problem with the postgresql modules that the
Gmakefiles have $(XEXTRALIBS) as dependencies, which resolves to -lipc
on cygwin, which causes an error. Is it safe to remove the $(XEXTRALIBS)
from the dependency line?
Please use the files on the above page for reference and ask for any
other info you may need.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
