[GRASS5] s.proj site header
Helena hmitaso at unity.ncsu.edu
Fri Sep 28 20:08:56 EDT 2001
Markus,
the quick reference of GRASS ascii formats is at
http://skagit.meas.ncsu.edu/~helena/grasswork/format.html
So if it is OK please put it at
http://grass.itc.it/gdp/html_grass5/index.html
under reference manual sections
Actually I noticed that the site ascii format has been
included into description of s.in.ascii in the users manual
however the info about the header was not included, so
you may want to put it there too.
(http://grass.itc.it/gdp/html_grass5/html/s.in.ascii.html)
>A new implementation seen in s.in.shape is there, but commented.
what do you mean by this?
>The time stamp facility does not appear to work at present.
I found this in manual for s.in.shape - does this mean that the time stamp
associated with the shape file is not imported?
Helena
Markus Neteler wrote:
> On Thu, Sep 27, 2001 at 04:12:44PM -0500, Helena wrote:
> > This appears to be a small but annoing bug - s.proj puts a comment at the
> > beginning of a projected
> > file, however other programs such as s.info do not like it
> > s.info lidar.utm
> > ERROR: G_site_new_struct: invalid # dims or fields
> > # s.proj input=lidar99 location=coastll mapset=helena dbase=/data/grassdata
> > output=lidar99.utm
> > 443873.48614701|3978547.65291465|#1 %5.054
> > So you have to remove it manually.
> > To keep the useful info on where the data came from I believe that instead of
> > #s.proj.......
> > this info should be passed as
> > description|s.proj.......
> > It is in main.c here:
> > if(outfile){ /* also write G_recreate_command as comment */
> >             Site_head sh;
> >             char buf[80];
> >             fprintf(outfile,"# %s\n", G_recreate_command());
> >             G_site_get_head (infile, &sh);
> >             G_site_put_head (outfile, &sh);
> > Can somebody please fix it, in case that it has not been done already.
> Hi again,
> I have modified the s.proj, now it doesn't write the desc in old style
> any more. A new implementation seen in s.in.shape is there, but commented.
> It needs to be finished (no time, sorry). See in CVS.
> Ciao
>  Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
