[GRASS5] s.proj site header
Markus Neteler neteler at itc.it
Fri Sep 28 09:14:12 EDT 2001
On Thu, Sep 27, 2001 at 04:12:44PM -0500, Helena wrote:
> This appears to be a small but annoing bug - s.proj puts a comment at the
> beginning of a projected
> file, however other programs such as s.info do not like it
> s.info lidar.utm
> ERROR: G_site_new_struct: invalid # dims or fields
> # s.proj input=lidar99 location=coastll mapset=helena dbase=/data/grassdata
> output=lidar99.utm
> 443873.48614701|3978547.65291465|#1 %5.054
> So you have to remove it manually.
> To keep the useful info on where the data came from I believe that instead of
> #s.proj.......
> this info should be passed as
> description|s.proj.......
> It is in main.c here:
> if(outfile){ /* also write G_recreate_command as comment */
>             Site_head sh;
>             char buf[80];
>             fprintf(outfile,"# %s\n", G_recreate_command());
>             G_site_get_head (infile, &sh);
>             G_site_put_head (outfile, &sh);
> Can somebody please fix it, in case that it has not been done already.
Hi again,
I have modified the s.proj, now it doesn't write the desc in old style
any more. A new implementation seen in s.in.shape is there, but commented.
It needs to be finished (no time, sorry). See in CVS.
Ciao
 Markus
