[GRASS5] [bug #998] (grass) Vask (curses) problems with KDE terminal
Markus Neteler neteler at itc.it
Wed Apr 3 15:41:02 EST 2002
On Wed, Apr 03, 2002 at 09:16:36PM +0100, Glynn Clements wrote:
> Request Tracker wrote:
> > Subject: Vask (curses) problems with KDE terminal
> > a long term problem on KDE is that in KDE terminal the carriage return (or whatever)
> > doesn't seem to work properly. The problem must be related to curses in the
> > VASK library.
> This sounds like a curses problem; in which case, GRASS can't do
> anything about it.
... if so: why does it work well for xterm? Or does curses behave
differently in xterm and KDE (or other) terminals?
Markus
