[GRASS5] [bug #998] (grass) Vask (curses) problems with KDE terminal
Glynn Clements
glynn.clements at virgin.net
Wed Apr 3 15:16:36 EST 2002
Request Tracker wrote:
> Subject: Vask (curses) problems with KDE terminal
> a long term problem on KDE is that in KDE terminal the carriage return (or whatever)
> doesn't seem to work properly. The problem must be related to curses in the
> VASK library.
This sounds like a curses problem; in which case, GRASS can't do
anything about it.
Glynn Clements <glynn.clements at virgin.net>
