[GRASS5] [bug #998] (grass) Vask (curses) problems with KDE terminal
Request Tracker grass-bugs at intevation.de
Wed Apr 3 11:39:56 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=998
Subject: Vask (curses) problems with KDE terminal
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: CVS
a long term problem on KDE is that in KDE terminal the carriage return (or whatever)
doesn't seem to work properly. The problem must be related to curses in the
VASK library.
It happens in all coordinate windows (g.region etc) as well as v.digit etc.
A screenshot (46kb) is here:
 http://mpa.itc.it/markus/tmp/kde_term_problem.gif
Here, using "t" in Digitize menu to toggle the vector type, end up with
above result.
When entering the raster resolution in g.region (menu1), the second line is reached
at mid of the line, not at the beginning.
I think that quite a few people are using KDE and KDE-term. It would be great to
have that problem fixed. In xterm everything is fine.
Thanks,
 Markus
-------------------------------------------- Managed by Request Tracker
