[GRASS5] raster file history question
Bernhard Reiter bernhard at intevation.de
Thu Apr 4 11:22:19 EST 2002
On Thu, Apr 04, 2002 at 05:54:39PM +0200, Markus Neteler wrote:
> > > the string "r.proj dgm1km loc=europa map=europa" should appear in
> > > the history. This is implemented in r.slope.aspect and s.surf.rst,
> > > but more complicated there. For my module (not r.proj) the command line
> > > string is sufficient to later remember the parameters which I used to
> > > generate that particular map.
> > > It must be something with argv[] or so.
You should be able to use the infos in argv[] and arc
to reconstruct parts of the command line.
You do not get the information about redirected file pointers,
because this is done by the shell.
	e.g.  cat - <parafile
argv[0] should have the programm executed.
argv[x] will contain the arguments.
http://www.cs.cf.ac.uk/Dave/C/section2_22_4.html#SECTION00224000000000000000
> ... all this code I have already written. I only don't know how to
> catch the command line. It must be possible as the parser does the
> same (catching the command line).
Professional Service for Free Software                 (intevation.net)
The FreeGIS Project                                       (freegis.org)
Association for a Free Informational Infrastructure          (ffii.org)
FSF Europe                                              (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020404/59a40668/attachment.bin
