[GRASS5] [bug #976] (grass) v.transform would not read that header of files
Carl Worth cworth at east.isi.edu
Thu Apr 4 11:30:47 EST 2002
On Apr 3, rgrmill at rt66.com wrote:
 > Radim wrote:
 > > BTW: I know, that it seems, that bug is in v.out.ascii, but because I
 > have
 > > never had such problems with v.out.ascii, I was not searching for
 > that.
 > > I can look at it, if you send me location with example map causing
 > problems
 > > (blank rows).
 > I'll see if I can find that set again, or another that does the same
 > thing.  Perhaps Carl can find the set that created the problem for him.
I'll have to look to see if I can dig something up or reproduce this.
My recollection is that it was a map generated by v.in.dxf.
-Carl
