[GRASS5] Library Issues
Bernhard Reiter
bernhard at intevation.de
Fri Apr 12 07:08:35 EDT 2002
Glynn,
thanks for the nice analyis.
Unfortunatly I know even less about these libraries then you do.
Unless you can find somebody to explain it to you,
I suggest that you just go ahead and try your best attempt to fix stuff.
If you think that any change might possibly cause a major hickup,
we should leave it for 5.1.x.
Bernhard
On Fri, Apr 12, 2002 at 11:45:46AM +0100, Glynn Clements wrote:
> I've been analysing the interdependencies between the various GRASS
> libraries, and wished to discuss some of the results.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020412/537b295a/attachment.bin
