[GRASS5] Library Issues
Radim Blazek blazek at itc.it
Mon Apr 15 02:47:12 EDT 2002
On Friday 12 April 2002 12:45 pm, Glynn Clements wrote:
> I've been analysing the interdependencies between the various GRASS
> libraries, and wished to discuss some of the results.
> 3. There are three pairs of libraries which are mutually dependent:
> 	im_lib      |ex_lib
> 	libgis.a    |libcoorcnv.a
> 	libstubs.a  |libdbmi.a
> 	libvect.a   |libdig2.a
> b)
> 	libstubs.a references:
> 	db_procedure_not_implemented
> 	libdbmi.a references:
> 	db_driver_add_column
> 	db_driver_update
> I haven't looked very far into this, but libdbmi probably needs to be
> split into two separate libraries; a high-level library above the
> drivers, which provides the API to clients, and a low-level library
> which provides utilities for the drivers.
We can just move db_procedure_not_implemented() to libstubs.a, it
is used only by other functions in that lib and should not be used
anywhere else.
> c)
> 	libvect.a references:
> 	dig_alloc_points
> 	libdig2.a references:
> 	dig_Rd_P_area
This is solved in 5.1, I would not recommend any changes in 5.0.
> What is the distiction between libvect.a and libdig2.a? Should they be
> combined? Or is all of this going to be replaced in 5.1?
In 5.0 it is more confused, in 5.1 I try to keep in vectlib all higher level
functions used by modules and in diglib all lower level functions like
R/W portable format or low level functions for topology structure
modifications.
Radim
