[GRASS5] Imagery GROUP file
Glynn Clements
glynn.clements at virgin.net
Sat Apr 13 01:14:36 EDT 2002
The use of the name "GROUP" for file which stores the current imagery
group conflicts with the "group" directory on filesystems which
perform case folding.
Someone has added a fix specifically for Cygwin:
#ifdef __CYGWIN__
#define GROUPFILE "CURGROUP"
#else
#define GROUPFILE "GROUP"
#endif
#ifdef __CYGWIN__
#define SUBGROUPFILE "CURSUBGROUP"
#else
#define SUBGROUPFILE "SUBGROUP"
#endif
However:
1. The same problem may occur with MacOS X, where case-folding
filesystems are not uncommon.
2. Users of conventional Unices might access a GRASS database which is
stored on a case-folding filesystem, e.g. an SMB share which is used
by both Unix and Windows systems, or a FAT partition on a dual-boot
Linux/Windows box.
3. This creates a portability problem regarding distributed datasets
(e.g. the "imagery" dataset, which includes a GROUP file).
Consequently, I've changed the definitions so that the files are
always called CURGROUP and CURSUBGROUP.
Users will need to rename (or re-create) any GROUP/SUBGROUP files
after updating to the new code.
Also, any supplied datasets (e.g. "imagery") will need to be updated.
Glynn Clements <glynn.clements at virgin.net>
