[GRASS5] Help using "configure"
VENKATARAMANAN RAJAGOPALAN vrajagop at du.edu
Tue Apr 16 11:18:33 EDT 2002
Hi Glynn,
I got the postgresql out of the way.  Now I am stuck with the ODBC include
files and the script complains that it is unable to locate the ODBC
library.  I downloaded the postgresql-odbc rpm and the unixodbc-devel rpm
and installed it. I also gave a path to the script as
/usr/include/pgsqll/iodbc.  It still complains. Do you suggest something??
Thanks
Venkat
