[GRASS5] Help using "configure"
Glynn Clements
glynn.clements at virgin.net
Tue Apr 16 12:01:40 EDT 2002
VENKATARAMANAN RAJAGOPALAN wrote:
> I got the postgresql out of the way. Now I am stuck with the ODBC include
> files and the script complains that it is unable to locate the ODBC
> library. I downloaded the postgresql-odbc rpm and the unixodbc-devel rpm
> and installed it. I also gave a path to the script as
> /usr/include/pgsqll/iodbc. It still complains. Do you suggest something??
GRASS needs UnixODBC (www.unixodbc.org), not IODBC. If you don't need
it, you can use the --without-odbc configure switch.
Glynn Clements <glynn.clements at virgin.net>
