[GRASS5] most recent snapshot
Markus Neteler neteler at itc.it
Wed Apr 17 05:06:46 EDT 2002
On Tue, Apr 16, 2002 at 06:40:35PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > It would have been nice if the tar ball had a non-generic name for it's
> > > > top-level directory like the normal tar ball releases do.
> > > I'd agree with that.
> > > "cvs update" will remove any files which have since been deleted, but
> > > extracting over an existing version won't.
> > > Can whoever maintains the snapshot build system (Markus?) change it to
> > > generate a unique directory name for the snapshot, to prevent this
> > > from happening.
> > Now I have reached this mail while cleaning the box. Yes, I can change that,
> > any suggestion for a unique directory name?
> I meant something which would change with each snapshot, using the
> date, e.g.:
> 	dirname=`date '+grass_%Y_%m_%d'`
O.k., I have changed all scripts. Now the snapshot tarballs contain
a unique directory, e.g.
tar tvfz grass50src_cvs_snapshot_exp_2002_04_17.tar.gz
-rw-r--r-- neteler/grass  4759 2002-03-01 05:12:19 grass50_exp_2002_04_17/aclocal.m4
drwxr-xr-x neteler/grass     0 2002-02-13 11:35:25 grass50_exp_2002_04_17/ALPHA64/
drwxr-xr-x neteler/grass     0 2002-02-13 11:35:25 grass50_exp_2002_04_17/ALPHA64/CVS/
... the same for 5.1.
Cheers
 Markus
