[GRASS5] trouble with r.in.bin size check
Moritz Lennert
fa1079 at qmul.ac.uk
Wed Apr 17 07:37:33 EDT 2002
I received the following in one of the responses to the questionnaire.
Moritz
----- Forwarded message from Pedro Camilo Alcantara Concepcion <camilo at pcbiol.fciencias.unam.mx> -----
> I have a bug report that i didn´t done because i didn't have time, i send
> here...
> Well i have some Landsat ETM+ 2000-2001 images, originaly rectified in PCI
> and exporter to raw, PCI export the image with a header embeded. well the
> problem is that: if i try to import with r.in.bin in the latest grass
> version 5.0pre2 or pre3 this command check the size of the file an reject
> the import, but if i use the r.in.bin of an old version the check routine
> didn´t exist and i can import the image correctly. I suggest to create a
> flag whith the option of check the size or resolve the problem in some
> equivalent way.
> Thank you for the development of free GNU software.
> Best Regards
> Camilo Alcántara
> Instituto de Geografía
> Departamento de Ordenamiento Territorial y Ecogeografia
> Morelia, Michoacan, México
----- End forwarded message -----
