[GRASS5] trouble with r.in.bin size check
Markus Neteler neteler at itc.it
Thu Apr 18 12:13:47 EDT 2002
Camilo,
could you provide a detailed error message generated from r.in.bin?
AFAIK the module's check routines runs well.
Thanks
 Markus
On Wed, Apr 17, 2002 at 01:37:33PM +0200, Moritz Lennert wrote:
> I received the following in one of the responses to the questionnaire.
> Moritz
> ----- Forwarded message from Pedro Camilo Alcantara Concepcion <camilo at pcbiol.fciencias.unam.mx> -----
> > I have a bug report that i didn´t done because i didn't have time, i send
> > here...
> > Well i have some Landsat ETM+ 2000-2001 images, originaly rectified in PCI
> > and exporter to raw, PCI export the image with a header embeded. well the
> > problem is that: if i try to import with r.in.bin in the latest grass
> > version 5.0pre2 or pre3 this command check the  size of the file an reject
> > the import, but if i use the r.in.bin of an old version the check routine
> > didn´t exist and i can import the image correctly. I suggest to create a
> > flag whith the option of check the size or resolve the problem in some
> > equivalent way.
> > Thank you for the development of free GNU software.
> > Best Regards
> > Camilo Alcántara
> > Instituto de Geografía
> > Departamento de Ordenamiento Territorial y Ecogeografia
> > Morelia, Michoacan, México
