[GRASS5] datum shifts
Glynn Clements
glynn.clements at virgin.net
Fri Apr 19 15:10:37 EDT 2002
rgrmill at rt66.com wrote:
> The nad27<->nad83 conversions are based on data tables. The data tables
> are shipped in ascii form. They have to be interpreted to binary by a
> program that ships with the package and then placed somewhere in the
> $GRASSBASE hierarchy. Currently I have them in $GRASSBASE/etc/nad. It
> would make more sense to me to put them in $GRASSBASE/lib/nad. Your
> input would be appreciated.
$GISBASE/etc is probably more correct. Presently, $GISBASE/lib only
contains libraries; all data tables are under $GISBASE/etc.
> The user modules must know where the data tables are stored, and that
> information should be compiled into the modules. I think that would be
> done by configure, but I don't know enough to say, much less enough to
> make the change myself.
With one exception[1], everything uses $GISBASE to determine
pathnames. That should be the case for the data tables, if at all
possible.
[1] The locale message catalogues don't, but I'll fix that now that
I've been reminded of it.
Glynn Clements <glynn.clements at virgin.net>
