[GRASS5] [bug #1023] (grass) v.extract again
Eric G. Miller egm2 at jps.net
Fri Apr 19 20:38:50 EDT 2002
On Fri, Apr 19, 2002 at 08:16:53PM +0100, Glynn Clements wrote:
> Request Tracker wrote:
> > I'm need v.extract again and it doesn't work.
> > I think that the problems are:
> > int cat_array[5000]; declare array of 5000 cat
> I've committed a fix which re-allocates the array as necessary.
> > To set the number of categories the program use
> >  recd = pcats->num;
> > I think this is the numbrer of the max. categorie, but not number of
> > categories. The code must be:
> >  recd = pcats->ncats;
> I'm not sufficiently familiar with category handling to be sure; can
> anyone else comment on this?
"num" is highest category number, "ncats" is total number of entries.
Sounds like it should be "ncats".  Category numbers certainly don't
have to be continuous.
Eric G. Miller <egm2 at jps.net>
