[GRASS5] [bug #1023] (grass) v.extract again
Glynn Clements
glynn.clements at virgin.net
Fri Apr 19 15:16:53 EDT 2002
Request Tracker wrote:
> I'm need v.extract again and it doesn't work.
> I think that the problems are:
> int cat_array[5000]; declare array of 5000 cat
I've committed a fix which re-allocates the array as necessary.
> To set the number of categories the program use
> recd = pcats->num;
> I think this is the numbrer of the max. categorie, but not number of
> categories. The code must be:
> recd = pcats->ncats;
I'm not sufficiently familiar with category handling to be sure; can
anyone else comment on this?
Glynn Clements <glynn.clements at virgin.net>
