[GRASS5] [bug #1023] (grass) v.extract again
Request Tracker grass-bugs at intevation.de
Fri Apr 19 11:03:46 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1023
Neteler:
I'm need v.extract again and it doesn't work.
I think that the problems are:
int cat_array[5000]; declare array of 5000 cat
but all the loop's like
for (i = 0; listopt->answers[i]; i++)
 scan_names (&cats, listopt->answers[i], &x);
 cat_array[cat_index] = x;
 cat_index++;
or
while (1)
  if (!fgets (buffr, 39, in)) break;
  sscanf (buffr, "%[a-zA-Z., -_/$%@!#0-9]", text);
  /*sscanf (buffr, "%s", text); */
  /*scan %s stops at whitespace?*/
  scan_names (&cats, text, &x);
  cat_index++;
or
while (x <= y)
 cat_array[cat_index] = x++;
 cat_index++;
and others don't check the max of the cat_array array (5000). I'm working with a small area of my country (I'm live at Uruguay a small country in South America).  I have more than 5000 lines to extract then I recieve segmentation fault message. I think put categories to extract in a array It's a bad idea.
To set the number of categories the program use
 recd = pcats->num;
I think this is the numbrer of the max. categorie, but not number of categories. The code must be:
 recd = pcats->ncats;
I debug another errors but I don't now what happend yet.
I don't have to much time to fix this errors (I'm a Civil Environment-Hydraulic Engineer not a programmer) but I'll try.
Thank you for your time. Fernando Pacheco.
P.D. -> Since 01/May/2002 where are mirror site of grass at http://www.dinama.gub.uy/grass/.
--- Headers Follow ---
>From neteler at itc.it  Fri Apr 19 17:03:29 2002
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 0585C13965
	for <grass-bugs at lists.intevation.de>; Fri, 19 Apr 2002 17:03:28 +0200 (CEST)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
	by mail.intevation.de (Postfix) with ESMTP id D45E71B6D6
	for <grass-bugs at intevation.de>; Fri, 19 Apr 2002 17:03:27 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g3JF3Rn29840
	for <grass-bugs at intevation.de>; Fri, 19 Apr 2002 17:03:27 +0200 (MET DST)
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g3JF3KK16999
	for <grass-bugs at intevation.de>; Fri, 19 Apr 2002 17:03:20 +0200
Received: (from neteler at localhost)
	by thuille.itc.it. (8.11.6/8.11.2) id g3JF3KV07869
	for grass-bugs at intevation.de; Fri, 19 Apr 2002 17:03:20 +0200
Resent-Message-Id: <200204191503.g3JF3KV07869 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
	by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g38CrWK06239
	for <neteler at itc.it>; Mon, 8 Apr 2002 14:53:32 +0200
Received: from rigel.dinama.gub.uy ([200.40.77.185])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g38CrOn10173
	for <neteler at itc.it>; Mon, 8 Apr 2002 14:53:30 +0200 (MET DST)
Received: from [200.40.77.186] (helo=mafalda)
	by rigel.dinama.gub.uy with smtp (Exim 3.34 #1 (Debian))
	id 16uVtx-00046o-00
	for <neteler at itc.it>; Mon, 08 Apr 2002 06:57:29 -0300
Date: Mon, 8 Apr 2002 10:28:50 -0300
From: "Ing. Civil H/A Fernando Pacheco" <fpacheco at dinama.gub.uy>
To: neteler at itc.it
Subject: v.extract again
Message-Id: <20020408102850.2facf838.fpacheco at dinama.gub.uy>
Organization: Direcci
X-Mailer: Sylpheed version 0.7.4 (GTK+ 1.2.10; i386-debian-linux-gnu)
Mime-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Resent-From: neteler at itc.it
Resent-Date: Fri, 19 Apr 2002 17:03:20 +0200
Resent-To: grass-bugs at intevation.de
X-Spam-Status: No, hits=0 required=5 tests=SUPERLONG_LINE
-------------------------------------------- Managed by Request Tracker
