[GRASS5] v.extract problems
Glynn Clements
glynn.clements at virgin.net
Sat Apr 20 06:51:00 EDT 2002
rgrmill at rt66.com wrote:
> I think the change you made is a good one, but I found another problem
> that might not be related. I ran the updated code against a vector file
> with more than 10,000 categories and tried to extract subsets ranging
> from 11 to more than 8,000 categories and consistently got seg faults.
> The problem always happens at line 272 in main.c.
I can't immediately see anything which would cause this.
Which options were used to specify the categories? I.e. were either of
"-n" and/or "file=" used?
Glynn Clements <glynn.clements at virgin.net>
