[GRASS5] v.extract problems
Glynn Clements
glynn.clements at virgin.net
Sat Apr 20 11:04:11 EDT 2002
[Roger: mail to rgrmill at rt66.com is bouncing.]
Roger Miller wrote:
> > Which options were used to specify the categories? I.e. were either of
> > "-n" and/or "file=" used?
> As far as I got in gdb, the fault at line 272 was caused because "&cats" in
> the arguments for G_get_cats was zero.
That can't happen; "cats" is a local variable, so "&cats" will always
be an address within the stack. I can only assume that gdb is "lying";
try compiling without optimisation (e.g. "CFLAGS= ./configure ...", or
edit the head.<platform> file).
> I didn't use -n. I got the same result using both file= and list=.
OK, that narrows down the possibilities.
> In my most recent test using the current code from CVS the full command line
> was:
> v.extract i=HidalgoCoTx o=test new=0 type=line list=39-50
> Category 39 is the lowest category. Category 42 is missing. If I use
> line=39-41 v.extract runs without errors. If I use line=39-43 v.extract gets
> a seg fault.
AFAICT, the most likely reason is that G_get_cat() is returning NULL,
and G_set_cat() is calling G_store(NULL), which segfaults.
I'll add a check for NULL labels.
> When it does run, I get a correct-looking dig_cats file, an empty dig_att
> file and a dig_ascii file with nothing but a header. The lack of results may
> be a completely different problem.
The "dig_att" file and the actual "dig" file are written by
xtract_{line,area}, which haven't been changed. AFAICT, v.extract
won't write a "dig_ascii" file.
Glynn Clements <glynn.clements at virgin.net>
