[GRASS5] Proj library update
Glynn Clements glynn.clements at virgin.net
Sat Apr 20 16:47:19 EDT 2002
Roger Miller wrote:
> I updated the proj library in the GRASS cvs to proj4.4.5.
> There is a potential problem.  The Gmakefile in the CVS was recently updated
> and the updated file did not compile the library.; it compiled the
> (alphabetically) first *.c file in the directory and stopped.  The file that
> I committed is the Gmakefile that I downloaded a couple days ago and modified
> to compile the added functions.
I suspect that you were trying to use the new Gmakefile with the old
versions of src/CMD/head/head.in and src/CMD/generic/make.mid.
The new Gmakefile *does* work with the new versions of those files;
the version which you committed wouldn't have ("$(AR)" is now the name
of the "ar" program, not the complete rule for building a library).
I've fixed the Gmakefile (i.e. re-applied the changes between versions
1.1 and 1.4), so it should work.
However, as a general rule, don't overwrite updated versions of files
with versions which were generated from an older version. "cvs commit"
should complain if you try to commit a file which is based upon an
older version than the one currently in the repository.
Instead, run "cvs update"; this will attempt to merge the changes into
the working version, and will tell you if a conflict arises.
Glynn Clements <glynn.clements at virgin.net>
