[GRASS5] Proj lib update
Bernhard Reiter bernhard at intevation.de
Sun Apr 21 16:16:21 EDT 2002
If you find code that is obviously redundant,
I vote for removing it.
On Sun, Apr 21, 2002 at 07:26:35AM -0600, Roger Miller wrote:
> Glynn pointed out that several programs in src.contrib/SCS used the proj
> library.  I've taken a look and found that UV is used in the code for
> v.out.dlg.scs, v.out.gef, v.mkquads.scs and v.proj.
> I looked into some of the other code in the src.contrib/SCS directories and
> found that several of the modules were duplicated in src/mapdev, namely
> Can the src.contrib/SCS version of these programs be removed from the
> distribution?
> Can these programs be removed from the distribution?
> I didn't go through all of the programs in the src.contrib/SCS directories.
> I imagine there is other duplicated and/or unused, unmaintained code.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020421/22129a5e/attachment.bin
