[GRASS5] Proj library update
Roger Miller
rgrmill at rt66.com
Sun Apr 21 14:58:13 EDT 2002
On Sunday 21 April 2002 13:31, Glynn Clements wrote:
> It's probably worth updating the version information in
> src/libes/proj/README.
done
> The datum tables (and their compiler) also need to be added at some
> point.
Where? the program nad2bin depends on projects.h, but is otherwise a
standalone program. It needs to be run at installation time but then is no
longer needed. The ascii tables should be shipped with the distribution.
nad2bin should be used during installation to convert them to binary and
store them in $GISBASE/etc/nad, after that the ascii form is no longer needed.
So, where do the nad2bin.c code and the ascii data tables need to be placed
in the CVS tree?
Roger Miller
