[GRASS5] Branching for 5.0.0 ahead
Markus Neteler
neteler at itc.it
Mon Apr 22 13:14:26 EDT 2002
On Mon, Apr 22, 2002 at 02:16:43PM +0200, Bernhard Reiter wrote:
> As self-appointed release assistant
> (nobody ever commented on me doing this)
> I remind you that our plan is to create the release branch this week.
> Thus this is your last chance to speak up that you still need
> more hours to check in your stuff.
> Do not start big additions to grass5 head branch
> without asking on the list.
Unless we find such severe things as the g.remove bug which just
killed all my raster maps from 8 month in my mapset, we should not
rush for the branch.
Also it is unclear to me who will tag it, I prefer a script with
some logic inside (reading src/CMD/lists/GRASS).
Due to the g.remove bug I have to re-do a lot of work, so I am
a bit busy.
> Work in progress that I've noticed:
> - d.zoom Radim
> - m.in.e00 Michel
> - proj Roger
also:
- v.buffer ?
- s.to.rast update
- new r.sun from Jaro
- m.proj[2] needs the datum update to be synchonized with [rsv].proj
(it is easier to explain to users that datum transform is not there than
telling them which modules are updated already - which is great indeed)
- html pages need update for the nad2nad
- what about v.in.shape (hi David)
> Please finish as soon as you can and let us know.
> If you cannot finish this within the next days,
> we might have to back the changes out and delay them to later releases.
If so, who would be doing that?
> As for the procedure:
> Markus, as GRASS project coodinator
> can you work with Glynn to actually create the Release branch?
mhhh, see above. some work is needed here.
> Glynn, you have done quite some coding lately on GRASS
> and you know a lot about CVS. Thus it would be great,
> if you could assist Markus here.
> You both have to make sure that the release branch only contains
> useful code we want to release and that you know is stable.
Here we need something recursive: we could make a proposal and need opinions
later since nobody will know all 3xx modules. Before really tagging a few
people should review the list of release candidates.
Then: Is everybody willing to work on the release branch? Just to verify, if
it makes sense to create it.
Markus
