[GRASS5] Branching for 5.0.0 ahead
Markus Neteler
neteler at itc.it
Mon Apr 22 13:29:22 EDT 2002
On Mon, Apr 22, 2002 at 06:09:58AM -0500, Helena wrote:
> Markus, did you get and submitted the new r.sun from Jaro? It should be much
> better than the old one.
Helena, Jaro,
just uploaded! Thanks for the submission.
Note that I have done a few cosmetics:
- Changed flag text:
-s Incorporate the shadowing effect of terrain
to be more clear.
- Updated Gmakefile to new style.
> May I ask somebody to run the latest submitted s.surf.rst with your data
> to make sure that we did not break anything when adding the anisotropy? We
> tested it, but it would be useful to have somebody run it independently
> (you do not have to test the anisotropy option as that is a very special
> case, but just make sure that you are getting the same results as before
> with some "standard" run).
> And if somebody really is bored could you also run v.surf.rst and
> r.resamp.rst to double check that they are working (although this is not
> critical as these two programs are not used too often).
> The cutting planes still crash nviz, but I did not have time to get the
> data to Glynn, but this is not a critical bug as it works most of the time
> and also most people do not use cutting planes. A note should be included
> into NVIZ manual.
Should be disable the "labels" and other non-existing things from the NVIZ
menu? To reduce user confusion?
Markus
> Bernhard Reiter wrote:
> > As self-appointed release assistant
> > (nobody ever commented on me doing this)
> > I remind you that our plan is to create the release branch this week.
> > Thus this is your last chance to speak up that you still need
> > more hours to check in your stuff.
> > Do not start big additions to grass5 head branch
> > without asking on the list.
> > Work in progress that I've noticed:
> > - d.zoom Radim
> > - m.in.e00 Michel
> > - proj Roger
> > Please finish as soon as you can and let us know.
> > If you cannot finish this within the next days,
> > we might have to back the changes out and delay them to later releases.
> > As for the procedure:
> > Markus, as GRASS project coodinator
> > can you work with Glynn to actually create the Release branch?
> > Glynn, you have done quite some coding lately on GRASS
> > and you know a lot about CVS. Thus it would be great,
> > if you could assist Markus here.
> > You both have to make sure that the release branch only contains
> > useful code we want to release and that you know is stable.
> > Part 1.2Type: application/pgp-signature
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
