[GRASS5] Branch deadline
Bernhard Reiter
bernhard at intevation.de
Mon Apr 22 15:03:01 EDT 2002
On Mon, Apr 22, 2002 at 05:33:50AM -0600, Roger Miller wrote:
> Do I remember the agenda correctly? As I recall, the deadline that is upon
> us now it the deadline for creating the release branch.
Correct.
> Once that is created
> there will be no new features added to the branch. There will still be some
> time for bug fixing before the actual release, so some code that is currently
> broken might actually be fixed before the release.
Yes. Note that only release critical bugs shall be fixed then.
I've also noted your proj update as one we want to have finished
before the branching.
> How much time will there be?
Between release branching and actual release? It depends.
For the current schedule check:
http://grass.itc.it/pipermail/grass5/2002-April/002477.html
For the procedure also see:
http://grass.itc.it/codemanagement.html
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020422/78883a57/attachment.bin
