[GRASS5] snprintf and other compile errors on IRIX
Frank Warmerdam
warmerdam at pobox.com
Tue Apr 23 09:01:34 EDT 2002
Paul Kelly wrote:
> Below is a list of the modules with the snprintf problem.
Paul, etc,
I would suggest that instead of Paul's suggestion, that we conditionally
compile in a GRASS version of snprintf() if the system does not provide one
and put it in libgis.a. The configure script should check for the
availability.
I don't have an IRIX system so I can't easily do the change, but if someone
else is willing to check it after I have done the work, I would be willing
to incorporate the required changes.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
