[GRASS5] snprintf and other compile errors on IRIX
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Apr 23 09:21:42 EDT 2002
Hello Frank
That sounds like a good idea. I've seen mentioned in lots of other places
the existence of GRASS versions of functions to replace those which were
non-existent or buggy on various systems. I would certainly be able and
willing to test it. For your information the snprintf I am using, I got
from http://www.ijs.si/software/snprintf/
Thank you
Paul
On Tue, 23 Apr 2002, Frank Warmerdam wrote:
> Paul, etc,
> I would suggest that instead of Paul's suggestion, that we conditionally
> compile in a GRASS version of snprintf() if the system does not provide one
> and put it in libgis.a. The configure script should check for the
> availability.
> I don't have an IRIX system so I can't easily do the change, but if someone
> else is willing to check it after I have done the work, I would be willing
> to incorporate the required changes.
