[GRASS5] s.vol.rst broken segmentation
Glynn Clements glynn.clements at virgin.net
Wed Apr 24 08:40:31 EDT 2002
Markus Neteler wrote:
> > We have just found that s.vol.rst has broken segmentation - we have a good
> > version, however somebody has probably changed something (e.g. it gives a
> > message "adjusted DMIN = .... which does not make much sense, because I
> > don't see a reason why dmin would have to be adjusted)
> Helena,
> I added a test for the 3D sites data, but cannot remember to have changed
> anything with "adjusted DMIN". The cvs diff doesn't display the
> initial version for some (strange) reason:
> cvs diff -r 1.1 main.c
> cvs server: main.c is a new entry, no comparison available
> While
> cvs diff -r 1.2 main.c
> is fine (and showing the added test).
The reason is that s.vol.rst was added to the release branch first; it
didn't exist on the head until the latest merge.
Glynn Clements <glynn.clements at virgin.net>
