[GRASS5] snprintf and other compile errors on IRIX
Bernhard Reiter
bernhard at intevation.de
Wed Apr 24 09:03:14 EDT 2002
On Wed, Apr 24, 2002 at 12:37:58AM -0700, Eric G. Miller wrote:
> I think I've fixed all the occurrences of snprintf that I had a hand in
> introducing.
If you improved the code while doing so, it is fine.
I believe that we need to have configure handle to add a replacement
function, if snprintf is not available for the system.
This seems reasonable as snprintf is standard for quite some time.
Even when its just a drop, I think that reducing the chance for
buffer overflows is always a good thing.
For everybody else: Becareful about grass checkins,
as Glynn will create the release branch soon.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020424/18662014/attachment.bin
