[GRASS5] can't latex progmanual
Moritz Lennert fa1079 at qmul.ac.uk
Mon Apr 29 10:50:48 EDT 2002
when I try to view the .dvi file I get
'xdvi.bin: DVI file corrupted'
when I try dvips on it I get
'dvips: ! unexpected eof on DVI file'
all of make, make pdf, make html fail (don't they all do a 'make all' to start with ?)
I'll just download the pdf-file  for now, and if it compiles normally for everyone else, I guess it's a local problem.
Moritz
On Mon, Apr 29, 2002 at 04:10:30PM +0200, Markus Neteler wrote:
> On Mon, Apr 29, 2002 at 04:10:41PM +0200, Moritz Lennert wrote:
> > Here's the output of make 2>&1 | tee ProgmanCompile.log, but again, I
> > don't see much of an error message, except at the end.
> ... there I see:
> Underfull \hbox (badness 10000) in paragraph at lines 75--77
> Underfull \hbox (badness 10000) in paragraph at lines 78--81
> LaTeX Warning: Reference 'Vector_Library' on page 42 undefined on input line
> 83
> this is a warning only. Don't you find the DVI file? Look at it with
> xdvi progmangrass50.dvi
> To get a PDF file, run:
> make pdf
> To get a PS  file, run:
> make ps
> To get a HTML set of file, run
> make html
> [see on top of the Makefile]
> Good luck,
>  Markus
> > Moritz
> > On Mon, Apr 29, 2002 at 03:21:47PM +0200, Markus Neteler wrote:
> > > Moritz,
> > > On Mon, Apr 29, 2002 at 03:25:03PM +0200, Moritz Lennert wrote:
> > > > Hi there,
> > > > I have trouble latexing the programmer's manual. It exits with
> > > > make: *** [all] Erreur 139.
> > > > I'm using:
> > > > TeX (Web2C 7.3.7) 3.14159
> > > > kpathsea version 3.3.7
> > > > on Debian Woody
> > > > I've attached the log file. I'm really no latex expert, so I don't
> > > > really understand what is wrong.
> > > the log file you have send does not contain an error, it
> > > seems to be cut. Please send a full log.
> > > Here it compiles fine...
> > > Markus
> > > _______________________________________________
> > > grass5 mailing list
> > > grass5 at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grass5
> > echo Rerun > progmangrass50.log
> > while grep Rerun progmangrass50.log >/dev/null 2>&1 ; do latex progmangrass50.tex ; done
> > This is TeX, Version 3.14159 (Web2C 7.3.7)
> > (./progmangrass50.tex
> > LaTeX2e <2001/06/01>
> > Babel <v3.7h> and hyphenation patterns for american, french, german, ngerman, n
> > ohyphenation, loaded.
> > (./scrbook.cls
> > Document Class: scrbook 1999/12/29 v2.5h LaTeX2e KOMA document class
> > (/usr/share/texmf/tex/latex/base/bk11.clo) (./typearea.sty
> > Package: typearea, Copyright (C) Frank Neukam, 1992-1994
> >                    Copyright (C) Markus Kohm, 1994-1999
> > )) (/usr/share/texmf/tex/latex/base/fontenc.sty
> > (/usr/share/texmf/tex/latex/base/t1enc.def)) (./progmangrass50.sty
> > (/usr/share/texmf/tex/generic/babel/babel.sty
> > (/usr/share/texmf/tex/generic/babel/english.ldf
> > (/usr/share/texmf/tex/generic/babel/babel.def)))
> > (/usr/share/texmf/tex/latex/graphics/graphicx.sty
> > (/usr/share/texmf/tex/latex/graphics/keyval.sty)
> > (/usr/share/texmf/tex/latex/graphics/graphics.sty
> > (/usr/share/texmf/tex/latex/graphics/trig.sty)
> > (/usr/share/texmf/tex/latex/config/graphics.cfg)
> > (/usr/share/texmf/tex/latex/graphics/dvips.def))) (./longtable.sty)
> > (/usr/share/texmf/tex/latex/base/makeidx.sty)
> > Writing index file progmangrass50.idx
> > (/usr/share/texmf/tex/latex/psnfss/times.sty) (./xspace.sty)
> > (/usr/share/texmf/tex/latex/fancyvrb/fancyvrb.sty
> > Style option: `fancyvrb' v2.7, with DG/SPQR fixes <2000/03/21> (tvz))
> > (/usr/share/texmf/tex/latex/base/ifthen.sty)
> > (/usr/share/texmf/tex/latex/hyperref/hyperref.sty
> > (/usr/share/texmf/tex/latex/hyperref/pd1enc.def)
> > Implicit mode ON; LaTeX internals redefined
> > (./url.sty))
> > *hyperref using driver hdvips*
> > (/usr/share/texmf/tex/latex/hyperref/hdvips.def
> > (/usr/share/texmf/tex/latex/hyperref/pdfmark.def)))
> > No file progmangrass50.aux.
> > (/usr/share/texmf/tex/latex/psnfss/t1ptm.fd)
> > (/usr/share/texmf/tex/latex/graphics/color.sty
> > (/usr/share/texmf/tex/latex/config/color.cfg)
> > (/usr/share/texmf/tex/latex/graphics/dvipsnam.def))
> > (/usr/share/texmf/tex/latex/hyperref/nameref.sty)
> > Overfull \hbox (341.43307pt too wide) in paragraph at lines 42--42
> > Overfull \hbox (341.43307pt too wide) in paragraph at lines 45--45
> > [1] [2] [3]
> > Overfull \hbox (0.90271pt too wide) in paragraph at lines 120--133
> > \T1/ptm/m/n/10.95 GRASS (Ge-o-graph-i-cal Re-sources Anal-y-sis Sup-port Sys-te
> > m) is a com-pre-hen-sive GIS with raster,
> > (/usr/share/texmf/tex/latex/psnfss/omsptm.fd)
> > Underfull \hbox (badness 10000) in paragraph at lines 141--142
> > (/usr/share/texmf/tex/latex/psnfss/t1pcr.fd)
> > LaTeX Warning: Reference `gfd_license' on page 4 undefined on input line 145.
> > Underfull \hbox (badness 10000) in paragraph at lines 143--146
> > [4]
> > Underfull \hbox (badness 10000) in paragraph at lines 192--198
> > Underfull \hbox (badness 10000) in paragraph at lines 199--200
> > Underfull \hbox (badness 10000) in paragraph at lines 201--202
> > Underfull \hbox (badness 10000) in paragraph at lines 203--204
> > [1]
> > Underfull \hbox (badness 10000) in paragraph at lines 229--236
> > Underfull \hbox (badness 10000) in paragraph at lines 237--238
> > [2] (./status.tex
> > Underfull \hbox (badness 10000) in paragraph at lines 1--2
> > Underfull \hbox (badness 10000) in paragraph at lines 3--4
> > [3]
> > Underfull \vbox (badness 10000) has occurred while \output is active [4])
> > [5] (./TODO [6]
> > Underfull \vbox (badness 10000) has occurred while \output is active [7])
> > [8] (./chapter1.tex [1] [2]
> > Chapter 1.
> > Underfull \hbox (badness 10000) in paragraph at lines 49--59
> > Underfull \vbox (badness 10000) has occurred while \output is active [3]
> > Underfull \hbox (badness 10000) in paragraph at lines 90--95
> > [4]
> > LaTeX Warning: Reference `GRASS_Information_Center' on page 5 undefined on inpu
> > t line 118.
> > t line 118.
> > t line 118.
> > Underfull \hbox (badness 10000) in paragraph at lines 136--137
> > [5]
> > Overfull \hbox (6.78607pt too wide) in alignment at lines 169--194
> > Package longtable Warning: Column widths have changed
> > (longtable)                in table 1.1 on input line 194.
> > ) (./chapter2.tex [6]
> > Chapter 2.
> > Underfull \hbox (badness 10000) in paragraph at lines 14--21
> > Underfull \hbox (badness 10000) in paragraph at lines 22--28
> > Underfull \hbox (badness 10000) in paragraph at lines 29--36
> > Underfull \hbox (badness 10000) in paragraph at lines 37--45
> > Underfull \hbox (badness 10000) in paragraph at lines 46--50
> > Underfull \hbox (badness 10000) in paragraph at lines 51--55
> > Underfull \hbox (badness 10000) in paragraph at lines 56--58
> > Underfull \hbox (badness 10000) in paragraph at lines 59--62
> > Underfull \hbox (badness 10000) in paragraph at lines 63--68
> > Underfull \hbox (badness 10000) in paragraph at lines 69--76
> > Underfull \hbox (badness 10000) in paragraph at lines 80--81
> > Underfull \hbox (badness 10000) in paragraph at lines 82--87
> > Underfull \hbox (badness 10000) in paragraph at lines 88--92
> > [8]
> > Underfull \hbox (badness 10000) in paragraph at lines 93--96
> > Underfull \hbox (badness 10000) in paragraph at lines 97--98
> > LaTeX Warning: Reference `Compiling_and_Installing_GRASS_Modules' on page 9 und
> > efined on input line 124.
> > LaTeX Warning: Reference `GRASS_CVS_repository' on page 9 undefined on input li
> > ne 141.
> > ne 141.
> > ne 141.
> > Underfull \vbox (badness 1888) has occurred while \output is active [9]
> > Overfull \hbox (3.63167pt too wide) in paragraph at lines 153--156
> > []\T1/ptm/m/it/10.95 Source code \T1/ptm/m/n/10.95 -- The source code for the f
> > unc-tions should be ac-com-pa-nied by lib-eral amounts
> > LaTeX Warning: Reference `UNIX_Environment' on page 10 undefined on input line
> > 172.
> > 172.
> > 172.
> > ) (./chapter3.tex [10]
> > Chapter 3.
> > Underfull \hbox (badness 10000) in paragraph at lines 21--42
> > [11]
> > Underfull \hbox (badness 10000) in paragraph at lines 96--105
> > Underfull \hbox (badness 10000) in paragraph at lines 107--113
> > [12]
> > LaTeX Warning: Reference `Writing_GRASS_Shell_Scripts' on page 13 undefined on
> > input line 120.
> > input line 120.
> > input line 120.
> > Underfull \hbox (badness 10000) in paragraph at lines 115--121
> > Underfull \hbox (badness 10000) in paragraph at lines 122--128
> > LaTeX Warning: Reference `Compiling_and_Installing_GRASS_Modules' on page 13 un
> > defined on input line 139.
> > Underfull \hbox (badness 10000) in paragraph at lines 130--140
> > LaTeX Warning: Reference `GIS_Library' on page 13 undefined on input line 155.
> > LaTeX Warning: Reference `Vector_Library' on page 13 undefined on input line 16
> > 7.
> > 7.
> > 7.
> > [13]
> > LaTeX Warning: Reference `Segment_Library' on page 14 undefined on input line 1
> > 73.
> > 73.
> > 73.
> > LaTeX Warning: Reference `Vask_Library' on page 14 undefined on input line 182.
> > LaTeX Warning: Reference `Display_Graphics_Library' on page 14 undefined on inp
> > ut line 200.
> > ut line 200.
> > ut line 200.
> > LaTeX Warning: Reference `Raster_Graphics_Library' on page 14 undefined on inpu
> > t line 200.
> > t line 200.
> > t line 200.
> > LaTeX Warning: Reference `Writing_a_Graphics_Driver' on page 14 undefined on in
> > put line 218.
> > put line 218.
> > put line 218.
> > LaTeX Warning: Reference `Digitizer_Mouse_Trackball_Files' on page 14 undefined
> >  on input line 223.
> >  on input line 223.
> >  on input line 223.
> > LaTeX Warning: Reference `Writing_a_Paint_Driver' on page 14 undefined on input
> >  line 225.
> >  line 225.
> >  line 225.
> > [14]) (./chapter4.tex [15] [16]
> > Chapter 4.
> > LaTeX Warning: Reference `GIS_Library' on page 17 undefined on input line 16.
> > LaTeX Warning: Reference `GIS_Library' on page 17 undefined on input line 24.
> > LaTeX Warning: Reference `Environment_Variables' on page 17 undefined on input
> > line 26.
> > line 26.
> > line 26.
> > Underfull \hbox (badness 10000) in paragraph at lines 15--28
> > LaTeX Warning: Reference `Writing_GRASS_Shell_Scripts' on page 17 undefined on
> > input line 31.
> > input line 31.
> > input line 31.
> > Overfull \hbox (12.22581pt too wide) in paragraph at lines 49--55
> > \T1/ptm/m/n/10.95 Subdirectories un-der the GIS-D-BASE are known as lo-ca-tions
> > . Lo-ca-tions are in-de-pen-dent databases.
> > Underfull \vbox (badness 4144) has occurred while \output is active [17]
> > (/usr/share/texmf/tex/latex/psnfss/t1phv.fd)
> > LaTeX Warning: Reference `Database_Access_Rules' on page 18 undefined on input
> > line 102.
> > line 102.
> > line 102.
> > Underfull \hbox (badness 10000) in paragraph at lines 98--104
> > [18]
> > Overfull \hbox (31.89261pt too wide) in paragraph at lines 107--109
> > []\T1/ptm/m/n/10.95 $GISDBASE/$LOCATION_NAME/$MAPSET and is re-turned by the li
> > -brary rou-tine G_location_path.
> > LaTeX Warning: Reference `Permanent_Mapset' on page 19 undefined on input line
> > 115.
> > 115.
> > 115.
> > LaTeX Warning: Reference `Region' on page 19 undefined on input line 160.
> > Underfull \vbox (badness 2443) has occurred while \output is active [19]
> > LaTeX Warning: Reference `Mapset_Search_Path' on page 20 undefined on input lin
> > e 168.
> > e 168.
> > e 168.
> > LaTeX Warning: Reference `Creating_and_Opening_a_New_Database_File' on page 20
> > undefined on input line 177.
> > [20]
> > (longtable)                in table 4.1 on input line 230.
> > Underfull \hbox (badness 10000) in paragraph at lines 241--245
> > Underfull \hbox (badness 10000) in paragraph at lines 246--248
> > Underfull \hbox (badness 10000) in paragraph at lines 249--253
> > Underfull \hbox (badness 10000) in paragraph at lines 254--255
> > Underfull \vbox (badness 6825) has occurred while \output is active [21]
> > LaTeX Warning: Reference `Mapsets' on page 22 undefined on input line 266.
> > LaTeX Warning: Reference `Mapset_Search_Path' on page 22 undefined on input lin
> > e 271.
> > e 271.
> > e 271.
> > LaTeX Warning: Reference `UNIX_File_Permissions' on page 22 undefined on input
> > line 272.
> > line 272.
> > line 272.
> > [22] [23]
> > Underfull \vbox (badness 10000) has occurred while \output is active [24])
> > (./chapter5.tex [25] [26]
> > Chapter 5.
> > (longtable)                in table 5.1 on input line 153.
> > [27]
> > LaTeX Warning: Reference `Mapsets' on page 28 undefined on input line 184.
> > LaTeX Warning: Reference `Raster_File_Processing' on page 28 undefined on input
> >  line 188.
> >  line 188.
> >  line 188.
> > LaTeX Warning: Reference `Multibyte_data_format' on page 28 undefined on input
> > line 213.
> > Underfull \vbox (badness 10000) has occurred while \output is active [28]
> > Underfull \hbox (badness 10000) in paragraph at lines 244--248
> > [29]
> > LaTeX Warning: Reference `Raster_Header_File' on page 30 undefined on input lin
> > e 295.
> > e 295.
> > e 295.
> > Overfull \hbox (0.53217pt too wide) in paragraph at lines 343--348
> > []\T1/ptm/m/n/10.95 The ge-o-graphic bound-aries of the raster file are de-scri
> > bed by the \T1/ptm/m/it/10.95 north,
> > [30]
> > Underfull \hbox (badness 10000) in paragraph at lines 386--388
> > Underfull \hbox (badness 10000) in paragraph at lines 391--392
> > Underfull \hbox (badness 10000) in paragraph at lines 393--396
> > Underfull \vbox (badness 5189) has occurred while \output is active [31]
> > Underfull \hbox (badness 10000) in paragraph at lines 469--471
> > LaTeX Warning: Reference `Raster_Category_File' on page 32 undefined on input l
> > ine 473.
> > ine 473.
> > ine 473.
> > Underfull \hbox (badness 10000) in paragraph at lines 472--474
> > [32]
> > Underfull \hbox (badness 10000) in paragraph at lines 492--493
> > (longtable)                in table 5.2 on input line 572.
> > [33] [34]
> > LaTeX Warning: Reference `Raster_Color_Table' on page 35 undefined on input lin
> > e 637.
> > e 637.
> > e 637.
> > Underfull \hbox (badness 10000) in paragraph at lines 636--638
> > Underfull \hbox (badness 10000) in paragraph at lines 643--645
> > [35]
> > LaTeX Warning: Reference `Raster_History_File' on page 36 undefined on input li
> > ne 683.
> > ne 683.
> > ne 683.
> > LaTeX Warning: Reference `Raster_Range_File' on page 36 undefined on input line
> >  700.
> >  700.
> >  700.
> > Underfull \hbox (badness 10000) in paragraph at lines 709--710
> > [36]
> > Overfull \hbox (46.03969pt too wide) in paragraph at lines 734--742
> > \T1/ptm/m/n/10.95 tines: G_something_raster (..., void *raster, RASTER_MAP_TYPE
> >  type, ...) G_something_c_raster
> > Overfull \hbox (62.51988pt too wide) in paragraph at lines 734--742
> > \T1/ptm/m/n/10.95 G_something_null_value (..., void *raster, RASTER_MAP_TYPE ty
> > pe, ...) G_something_c_null_value
> > Overfull \hbox (39.6557pt too wide) in paragraph at lines 734--742
> > \T1/ptm/m/n/10.95 (..., CELL *cell, ...) G_something_f_null_value (..., FCELL *
> > fcell, ...) G_something_d_null_value
> > [37]
> > Overfull \hbox (5.2423pt too wide) in paragraph at lines 835--837
> > []\T1/ptm/m/n/10.95 This bi-nary file con-tains the range (min-i-mum and max-
> > [38]) (./chapter6.tex [39] [40]
> > Chapter 6.
> > Overfull \hbox (0.83908pt too wide) in paragraph at lines 7--9
> > \T1/ptm/m/n/10.95 This chap-ter pro-vides an ex-pla-na-tion of how vec-tor map
> > lay-ers are ac-com-mo-dated in the GRASS
> > Underfull \hbox (badness 10000) in paragraph at lines 13--19
> > Underfull \hbox (badness 10000) in paragraph at lines 20--32
> > LaTeX Warning: Reference `What_is_a_Raster_Map_Layer' on page 41 undefined on i
> > nput line 39.
> > nput line 39.
> > nput line 39.
> > Underfull \hbox (badness 10000) in paragraph at lines 33--41
> > LaTeX Warning: Reference `Mapsets' on page 41 undefined on input line 46.
> > Underfull \hbox (badness 10000) in paragraph at lines 42--47
> > [41]
> > Overfull \hbox (1.2103pt too wide) in paragraph at lines 61--64
> > []\T1/ptm/m/n/10.95 For ex-am-ple, a map layer named \T1/ptm/m/it/10.95 soils \
> > T1/ptm/m/n/10.95 would have the files \T1/ptm/m/it/10.95 dig\T1/ptm/m/n/10.95 /
> > \T1/ptm/m/it/10.95 soils, dig_att\T1/ptm/m/n/10.95 /\T1/ptm/m/it/10.95 soils, d
> > ig_plus/soils,
> > LaTeX Warning: Reference `Vector_Library' on page 42 undefined on input line 83
> > grass5 mailing list
> grass5 mailing list
