[GRASS5] can't latex progmanual
Glynn Clements
glynn.clements at virgin.net
Mon Apr 29 14:53:41 EDT 2002
Moritz Lennert wrote:
> I have trouble latexing the programmer's manual. It exits with
> make: *** [all] Erreur 139.
Error 139 is 128+11, i.e. a child process terminated with signal 11
(SIGSEGV, "Segmentation fault").
It isn't possible to deduce anything further from the log files.
It may be possible to obtain more information by running the
individual commands directory. OTOH, you might even need to use
strace/gdb/etc to determine the problem.
Glynn Clements <glynn.clements at virgin.net>
