[GRASS5] Script to build babyGRASS for handhelds
Carl Worth cworth at east.isi.edu
Mon Apr 29 13:27:24 EDT 2002
On Apr 29, Markus Neteler wrote:
 > Thanks for the hint - the size is shrinked by around 50% to
 > 1.7MB.
Excellent.
 > If anyone else is interested, I have another script now to
 > extract babyGRASS from a common code directory into a new
 > tarball. Also the compile script is improved. Let me know,
 > then I send it to you.
Markus, I'd be interested in this. Perhaps you could commit it into
CVS somewhere.
 > Currently we cannot login into the Skiff cluster (down), otherwise
 > inital GRASS/iPAQ binaries would probably already available.
Other options are to compile GRASS natively on an iPAQ or using a
cross-compiler, (which I have done successfully for very large portions
of GRASS). I have both options readily available here, so I can
compile up this lightweight GRASS distribution and contribute it to
the Familiar Linux distribution for easy installation on handhelds.
-Carl
